Reply To: Folder with multiple music files and switching album covers
Home Forums Product Discussion & Questions BeoSound Folder with multiple music files and switching album covers Reply To: Folder with multiple music files and switching album covers
#56572
Carolpa
    • Topics Started 6
    • Total Posts 258
    Just some questions:
    1. is the NAS only LAN connected to the same network, correct?
    2. I presume a album cover is embedded in all music files, correct? Or just in the first?
    3. do the pictures exceed 1000×1000 pixels?
    4. do you use a DLNA server? Which one?
    5. did you add the folders with the “analogue music” to the DLNA server?
    6. how do you select a folder on the BS5e?
    7. NL mag ook 🙂 ?
    and yes, I think it should be possible!
