Reply To: Beolab 3500 and Beocenter 8500 – possible?
Home Forums Product Discussion & Questions BeoLab Beolab 3500 and Beocenter 8500 – possible? Reply To: Beolab 3500 and Beocenter 8500 – possible?
#56563
Madskp
GOLD Member
    • Denmark
    • Topics Started 39
    • Total Posts 965
    I’m also wondering (and judging from your previous posts you might know this @Madskp!), if I bring my BV8 TV into the Masterlink network, then the TV becomes the ‘controller’, so to speak, and powers the network, so I could use either  the 1611 or the 1614, but not both?
    Probably the 1614 should work in this scenario*, however since you have the 1611 this is more flexible if you decide to get a different TV that does not have Masterlink.
    *My experience is based on use with a Beocenter 6-26, so actually a little unsure if there is any difference to using it with a Beovision with Masterlink in that regard.
