Reply To: Beocom 6000 MK1 Base pin code
#5655
Guy
    • Warwickshire, UK
    Evening!
    How frustrating!!!  As the person who posted about connecting directly to a router I feel somewhat responsible!
    Maybe try resetting the handset before then trying to register:
    If a Mk1 (no INT button) press (dot) 7 000 9
    If a Mk2 (with INT button) the Service Menu:  9#9#9*INT allows you to reset the handset.
    Otherwise, try a reset followed by leaving the handset on the charging pyramid base.  (Logically a PIN should only be required if the handset and PSTN are physically separated, hence worth a try!)
