Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3500 and Beocenter 8500 – possible? › Reply To: Beolab 3500 and Beocenter 8500 – possible?
17 June 2024 at 15:30
#56546
GOLD Member
Great deal 😀
I don’t know if the BV8 has the timer, but if not it is possible to not show the missing clock on the BL3500. There are three display setting where one is not showing the clock. You can switch between them by holding the timer button and touching the mute button on the BL3500
Regarding the connection to the BV8 you can not use the 1614 when you already have the 1611.
You have to divide the masterlink connection with a junction box
