Reply To: Back to old things: Beovox P50…
Home Forums Product Discussion & Questions BeoVox Back to old things: Beovox P50… Reply To: Back to old things: Beovox P50…
#56539
Antonio Sanchez
    • Topics Started 1
    • Total Posts 2
    Hey @ajames, I’ve just got  a couple of P45 and I don’t know how to mount them on the wall. You speak about drilling amidst the two triangular shaped holes… I don’t really get it. And then you drill the back of the speaker? I don’t think so, buy I just can’t picture it. Do you have any photos/quick sketch? Any kind of help is very welcome 🙂
    I cleaned them and swapped all electrolytics. And then re-grilled them with a very soft & thin cloth. They are looking great, but they are also sad because of not being mounted  🙁
    Cheers!
