Reply To: Beogram CD 50 – How to Select Proper Setting For ‘Master Voltage Switch’?
Home Forums Product Discussion & Questions BeoGram Beogram CD 50 – How to Select Proper Setting For ‘Master Voltage Switch’? Reply To: Beogram CD 50 – How to Select Proper Setting For ‘Master Voltage Switch’?
#56505
vtlynch
    • Topics Started 1
    • Total Posts 5
    Progress update: ‘Disc holder, Lower’ (9132) is dislodged.
    The CD drive ‘Sub-chassis’ (Service Manual Part 9156) has two (permanently attached?) pins for seating the ‘Disc holder, lower’ (9132). The ‘Disc holder, lower’ is also held by the ‘Lift Arm’ (9130).
    My ‘Disc holder, Lower’ is dislodged from the right Lift Arm bracket. As a result, the entire machine is essentially jammed up.
    My plan of action is to remove the two screws holding in the Lift Arm. The service manual diagram shows the entire Lift Arm should come free, and Im assuming I will be able to reposition it back into place. I did some searching but was not able to find a thread/documentation of this exact problem?
    I have attached photos showing my drive and the service manual diagram of the corresponding part.
    I plan on doing this tomorrow and will check back here if anyone posts advice if this is the right/wrong course of action.
    ____
    In addition, and as expected in the year 2024, I can see the rubber belt drive for the tray has essentially melted. I found this page that says a square 44mm x 1.2mm belt drive works. Unfortunately, there does not seem to be a cheap and fast way to get one in the USA. Im going to try to a generic cheap package from Amazon and hope its close enough. Might place an order with Beoparts later, just dont want to wait 2 weeks at the moment.
