Home Forums Product Discussion & Questions BeoLab Beolab 7-2 distortion only on some soundtracks Reply To: Beolab 7-2 distortion only on some soundtracks
#56450
Die_Bogener
I have something like that with HDMI and DVD Player Software.
The sound is playing with 16-bit resolution. A loud section of the music/movie can use these 16-bit 100%.
If you use a software, that is increasing this 16-bit range to make it louder again, then there is a software bug… it’s an overrun of the system, you would need 17 or 18 bit or even more… and these bits are not available.
It’s a cheap and mean software bug of calculating the value.  It would be better, to limit the sound to the maximum instead making a overrun…
