Home Forums Product Discussion & Questions BeoLab Beolab 7-2 distortion only on some soundtracks Reply To: Beolab 7-2 distortion only on some soundtracks
#56446
DT79
FYI, in case anyone finds this with a similar issue…
I’ve confirmed that it really is just certain soundtracks. I dug out the disc of the rip mentioned above where I first noticed the issue and it played fine, even when turned up very loud: no distortion. The rip was not 1:1 I had converted the soundtrack to save space.
I think the issue might also be with the Anthem Room Correction EQ curve as I tried toggling it off when experiencing the distortion and it reduced significantly.
I think it might be a combination of the characteristics of the soundtrack and the ARC EQ.
