June 4, 2022 at 11:29 am
#5627
Hello, Just a guess, but with B&O audio systems from the 90s the store action has always been ‘sound’, (adjust), ‘store’ ‘store’. Not just one hit of the store button but two. Julian
Thanks. I gave that a try. Pressed Sound, then adjusted the to something sensible like 14. Pressed store twice. After the first press the on screen sound level disappears then pressing it again does appear to do anything. Turned the TV off and then on again and the volume was back at 42 :(. Tried several times with the same result.
This reply was modified 3 weeks, 4 days ago by
Shun.
