June 3, 2022 at 11:00 pm
#5621
matador read post#5604., My5513 type 4002 does not use the thrust pad and the “play” in the platter is normal. Its a self centering spindle. During my pre-restore inspection I notice that the zero force balancing screw is loose , just as beolover said it would be .
