Reply To: Beocom 2, what is missing ?
#5530
Guy
  • Warwickshire, UK
  • Topics Started 3
  • Total Posts 130
A further thought: If your internet modem/router has built in DECT, then you may be able to connect the Beocom straight to it without purchasing a PSTN. I have used Beocom 6000s like this in the past – there will be reduced functionality but calls in/out should work fine.
