May 31, 2022 at 4:51 pm
#5529
So a power supply with a phone line would not work ?
If you mean an original Beocom 2 PSTN charging base, then I cannot be sure. As stated in the FAQ, Beocom 2s were often updated with new SW to enable them to work with other B&O phones (eg BC6000) and share a PSTN. If the Beocom 2 that you are buying has had the SW update, then I am not sure if it will work with the original PSTN/charging base. Some of the Beocom 2s original PSTN charging bases simply had the phone line cut off once the phone itself had the SW upgraded.
