Reply To: NL/ML Netlink Converter mit BS 9000
#5509
Tignum
Beoworld Member
  • Netherlands
  • Topics Started 0
  • Total Posts 32
Hi Thorsten, this should be possible! Let me try to send you the NL/ML converter (aka BLC) manual. I think it should be set as a Video Master (as the BeoSound 9000 is already the Audio Master in your ML network). Google the old forum for BLC. I also found some good support there a while ago. Regards, Johan
