Home › Forums › General Discussion & Questions › BeoMaster 7000 to BS Core › Reply To: BeoMaster 7000 to BS Core
29 May 2022 at 08:51
#29185
Hi Kiran,
I have just sent you a full reply to your email, but basically I suggest using the Powerlink outputs of the 7000 instead of the Line socket, this generally works better as you have the option of adjusting volume from the Beo4 or the B&O app when switching sources on the 7000 (eg. as the Beogram is usually a bit quieter than other sources).
This cable will connect from one of the Powerlink outputs of the 7000 to the 3.5mm line inputs of your Core:-
Please set the Beomaster volume to a high level (50-75%) to give you the full range of volume control from the B&O app.
Kind regards, Steve.
