Reply To: BeoMaster 7000 to BS Core
#5442
Steve at Sounds Heavenly
  • Topics Started 11
  • Total Posts 74
Hi Kiran,
The cable you are using is wired as an output for the Powerlink socket of the 7000 to the Core. Please set the 7000 volume to around 70 and then this will work well with the speakers connected to the Core.
If you prefer to use the system with the speakers connected to the 7000 and the Core linked as an input to the 7000 Tape port then please use this cable instead (please note that this link won’t work until Tuesday morning as I’m away from work at the moment):-
https://soundsheavenly.com/playmaker-and-essence-wireless-streaming/84-378-rj45-to-aux-input-cable-add-core-essence-or-playmaker-to-your-bo-system.html#/9-length-18m
Please feel free to post the Beogram cables that you purchased back to me if you would like a refund and I can help with getting everything working.
Kind regards, Steve.
