Madskp
GOLD Member
Perhaps if the audio was fed into a Playmaker, auto-sense on its line-in could switch on connected PL speakers and you would have Beo4 volume control also?  You’d probably need the PM in A.OPT 4 so that it will respond to the ‘link mode’ volume commands that are used to activate the BL1615,
Oh yes, didn’t think of that as an option. That would be an even more seamlessly solution, especially if the BEO4 is programmed to send link commands.
and you’d have to avoid the A.MEM command as this would put the PM into Airplay mode.
Yes A.MEM can not be used from the main room in this scenario as the PM also seems to prioritize Airplay over Line in.
