May 28, 2022 at 7:25 pm
#5397
Hi Everyone Thanks for the advice. MM, the Aux/TV port is unfortunately an input.
Are you sure/did you try it?
That port used to be the connection to a compatiple BV ..….and this works both ways.
P.S.
It is very long ago that I used it this way 🤔
