Reply To: No Bluetooth on Beovision Avant 75
#5396
cyberc
  • Topics Started 1
  • Total Posts 4
Since you write about ‘a changed mainboard’, I assume that you have a MK1 version. In that case it is very easy to answer – altough you might not be pleased – there is no bluetooth support whatsoever on that tv! MM
Thanks for your reply.
If the tv doesn’t support Bluetooth why does the instruction manual refer to how it is used etc?
