May 28, 2022 at 6:41 pm
#5391
You can use that Line-In/Out port, but then the Beomaster will not play anything thru its own amplifier. That existing clear plastic plug is a crossover, output-to-input. (I used that jack to loop in an equalizer.) I don’t know about selecting sources with the remote control and proper Core integration, but would use the output pins on the Tape2 connector to get a line-level output (which is always supplied). That way no surprises when someone plugs passive speakers into the Beomaster and it “doesn’t work”!
