May 27, 2022 at 7:47 pm
#5355
Hi Cavscout,
Thanks for your enquiry. If your amplifier has a built in phono pre-amp, then you just need this cable to connect it to the phono input of the amplifier:-
If the amplifier doesn’t have a pre-amp, you will need this pre-amp kit instead, which comes with all cables needed and full instructions, ready to “plug and play”:-
https://soundsheavenly.com/beogram-record-players/12-2196-pre-amp-bundle-for-bo-beogram-and-all-turntables.html#/36-output-5_pin_din_aux/41-power_supply-uk – please choose the “Twin RCA plugs” output option for your amplifier.
If you are unsure about whether the amplifier has a built-in pre-amp, please email me the full model number and I will be pleased to confirm this.
Kind regards, Steve from Sounds Heavenly.
This reply was modified 4 weeks, 1 day ago by
Steve at Sounds Heavenly.
