Reply To: missing BG4000
#5320
Bernie
    Thanks Craig,
    I had a problem not been able to find the regulator down here in New Zealand, spent ages trying to find an equivalents table but no luck. Eventually found BA06BC0T, don’t know what the difference is but specs look the same. Just wanted to double check on the neon, I never liked mains voltage on low voltage PBCB’s. When the transformer turns up in 6 days will get into it, it will be good to get it working again after 10 years.
