26 May 2022 at 08:53
#29259
Bernie
Sorry for the late reply…..been a bit busy with work etc. The GL90 neon was connected directly to the incomming 230vac supply down stream of the fuses…..the supply needs to be connected through the reed relay contacts just as it is now (so the lamp only comes on when start is pressed) I think all the parts I used are documented in this post….but if you need any more info let me know
Regards Craig
