23 May 2022 at 10:12
#29291
With a BeoMaster with built in pre-amp (some BeoMaster 4500s have that), you could skip a box (I am not sure if more recent BeoSounds that have a MasterLink connection can control BeoGrams through their AUX sockets). It will also require some persistence to program the BLC. But unless I oversee something I believe it could work.
As far as I know only the Ouverture (Beosound 4000) has both datalink and masterlink. But of course the Ouverture has no RIAA amplifier (which the 8002 needs). If using a separate RIAA amp you would need to be sure that the datalink signal is passed to the correct datalink pin, as explained in this thread (see post by joeyboygolf): https://archivedforum.beoworld.co.uk/forums/t/41586.aspx
