Reply To: BEOLAB 6000: looking for DC voltage for DIY Bluetooth
#5167
pilatomic
    @Pilatomic: thnx! This sounds really helpful. One question. Is it correct that the +/-35v at the C5 capacitor is always available? So also when the BeoLab 6000 is in stand-by/Red LED on?
    The voltage across C35 will only be present when the LB6000 is turned on. ( Relay RL1 closed )
    If you need a permanent voltage, you can find it across C31. It will probably have quite a lot of ripple, but the DC/DC converter should be able to deliver a stable output voltage nonetheless.
    • This reply was modified 1 year, 4 months ago by Keith Saunders.
    • This reply was modified 1 year, 4 months ago by pilatomic. Reason: Remove quotes
