Reply To: MasterLink USB adapter
Home Forums Product Discussion & Questions BeoLink MasterLink USB adapter Reply To: MasterLink USB adapter
#50990
B3OHACK3R
    • Topics Started 4
    • Total Posts 148
    A very great use case which has been requested by many
    Yes, certainly makes BL2000 and BL3500 a lot more useful again. ๐Ÿ™‚
    is it possible to control it directly by serial Rs232 (with/without a level converter) ?
    No, that won’t work unfortunately. It’s a half-duplex symmetrical bus working at very low voltages (+/- 0.25V). It is a bit similar to RS422 but won’t work with such transceiver chips due to the low voltages. Also you have to provide power to the data pins as well as to the ML detect pin.ย  So quite a circuit required and anything else than straight forward.
    Thank you for your excellent work !
    Thanks ๐Ÿ™‚
