Further to Nanoloop’s comment below – I believe that you will need the slightly thicker fully wired Mk2 version of the Powerlink cable in order to ensure correct on/off and muting function.
Here’s an example as supplied by the site sponsor: https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html
It’s worth checking with Steve that the Mk2 is correct – I am 99% sure 😀
(EDIT: Make sure that your disconnect the ML cable as it is not necessary in your configuration, and will probably stop the Passive from working correctly. The Passive’s ML input is for the situation when it is powering speakers in a Link Room away from the main system, and in such a setup it would need the IR eye also.)
This reply was modified 1 month, 1 week ago by
Guy.
