May 16, 2022 at 8:40 am
#5053
Thank you Guy, after a little search the Beolink MCL82 type 2041 works with the BS5000 and BC7700. The search also returned a little extract from the Beoworld product page that says: “It was superseded by the later MCL2 system which used Beolink 1000 codes.”
So I’ll assume it may potentially not work with moderne remotes. When I had a full 5000 system, I used little cheap IR repeater to help the return of the IR signal to the remote. It did work when the same repeater don’t with modern Beo remotes (1000/4/6/5000). So the theory is it wont work.
To the OP, apologies for this little out of topic, I felt like it didn’t deserved a full thread on it’s own. It’s now ended.
This reply was modified 1 month, 2 weeks ago by
matador.
