Reply To: B&O Loudspeaker Switch IR Eye pinout help requested
#5042
matador
    • Paris France
    I made some notes when I used an MCL sensor as a Beolink PC IR sensor. The three connections that you require are: Ground – Brown IR Data – Yellow +5v –
    Hi Guy, does that mean you can use MCL IR sensors (square ones) with more modern hardware that need round sensors ?
    To be more precise, would an MCL82 type 2041 sensor be able to control a beolink passive ?
    Thank you.
