Can someone tell me to which pins i should connect the wires from the MCL IR? i suppose it’ll be the Green: 5v, Brown: ground? and White: Data. But correct me if i’m wrong!
I made some notes when I used an MCL sensor as a Beoport IR sensor. The three connections that you require are:
Ground – Brown
IR Data – Yellow
+5v – Green
White is indeed a data connection but is used for relaying the other functions within the MCL sensor, particularly from pressing the buttons (eg Mute and Timer).
Hopefully you can work out the correct 5 pin DIN pins from having a look at the internal wiring of the loudspeaker switch.
IMPORTANT EDIT: I have just realised that I actually used a VX sensor (similar to MCL but without Mute and Timer buttons) when I was experimenting. The VX sensor only has three wires, hence IR data had to be Yellow by process of elimination! I think that in your MCL sensor then ‘White’ may well be the data connection that you need. Sorry for the confusion!
This reply was modified 1 month, 2 weeks ago by
Guy.
