Reply To: Back to old things: Beovox P50…
#5025
matador
    • Paris France
    Still thinking on the better way to fix the magnet. In the meantime I’d like advices on something: the frets.
    They’re in a coarse and stiff fabric glued on a thin panel made of wood and plastic for the wedge. the fret is fixed to the speaker with weird velcro strips, some in the groove in the edge of the speaker, and more wide bands in the flat surfaces of the front panel (those looks like added afterwards, not originals). The fabric is folded to follow the beveled shape of the wedge and not deformed like in the S45 or C30 I’ve seen.
    I’d like to know if this fabric is original or not. It is actually in not so good shape and the speaker will benefit of changing it all (once the drivers are fixed!) but if they are original, I’d rather try to rescue them.
    I’ve noticed P45, which seems to be technically identical have everything needed to clip their frets, like holes in the front panel which P50 don’t have.
    So the two question I have are:
    • Are those frets original (fabric and structure)?
    • How where they originally fixed to the enclosure?
    Below some pics. Thanks to alls.
    IMG_9536IMG_9535IMG_9534IMG_9533
