Reply To: BS Core operation via Essence remote integrated with Avant
#5017
Millemissen
GOLD Member
    • Flensborg/Danmark
    You will not be able to use the remote with the Core in that case.
    Integrated means being part of the BV.
    Since the Avant is ir-based however, you would have to configure the remote to ir-control.
    This way – at least – you could control the volume.
    • This reply was modified 1 year, 4 months ago by Millemissen.
