Reply To: connections help πŸ˜…
#5010
Kiran
GOLD Member
    I would go for a BS Core and connect all the Beolabs to this. You will need to daisy chain all the speakers using their Powerlink connections or you can go a step further and split the Powerlink signal for parallel connections.
    I would then connect the TV to the Core via optical out if the TV has it or last resort would be to use the headphone jack of the TV.
    You would then be able to listen to anything playing on the TV or you can Airplay / Cast to the Core for music only… πŸ‘πŸ»πŸ’―
