Home Forums Product Discussion & Questions BeoSound Beosound Core – connectivity and alternatives Reply To: Beosound Core – connectivity and alternatives
#49980
BeoMatthew
    1) Need to connect up my turntable as this is my main and most enjoyed source. It’s on the other side of the room from where the speakers will be and can’t be relocated. Ok.
    2) I use Roon for streaming. As I understand it the Beosound Core will show up as an audio device via Chromcast in Roon so all good there. Correct. The Core is not Roon Ready, but would use Chromecast as you describe.
    3) Does the Core have its own in-built volume adjustment? I.e. I can connect my phono preamp into the Core’s analogue input and control volume in the Core via the B&O app or a B&O remote if I get one? That’s correct.  It’s a fully integrated audio system in that regard.
    4) What are opinions of the quality of the analogue to digital conversion in the Core? Am I still going to get a high quality result from my analogue front end? I use a BeoCenter 6500 with one of mine and the sound is terrific.
    5) What’s the best way of connecting from Core to BL18s assuming the Core is positioned near the TT and optical isn’t an option*? Would I be right in thinking I could use the Cat6 as a power link cable, so I could go from Core to right hand BL18 (this would need a short RJ45 female to RJ45 male extension to get to the speaker) then another Cat6/powerlink cable between the speakers? Is there any advantage to going wired vs Wireless these days? There are a lot of correct answers to this, because the BL18s have a wide variety of inputs. You categorically CANNOT use Cat6 as a direct replacement for PowerLink (such that you would connect it to the RJ45 ports on either the core or the speaker, however you can use RCA baluns to get your signal to the other side of the room using a Cat6 cable.
    You’d go RJ45PL to RCA adapter -> RCA balun -> Cat6 -> RCA balun -> RCA cable to each speaker
    6) I believe the powerlink cables even the new RJ45 style connections send an analogue signal, is that right? They send an analog L+R signal, plus turn-on voltage. The speaker line-senses when connected via RCA
    7) *It’s a bit convoluted but if having a wired digital connection is the decisively best option then I could go Core>optical to coax converter>coax cable>installed coax cable>coax cable>coax to optical converter>BL18. Not sure if it will even work through all those connections. You’re not going digital to the BeoLab 18s. Don’t worry about this step. You’re analog from the time you leave the Core.
    8) Are there any decent 3rd party alternatives to the Core that will be Roon compatible and allow the connection of an analogue source? Any streaming preamp I suppose, which is essentially what I already have, but I presumably wouldn’t have any option to run the BL18s with a BL19 in optimal/intended fashion. The Bluesound Node is a terrific option and dispenses with having to translate PowerLink adapters and such. So long as you don’t care about the BeoLink Multiroom ecosystem it would be a great alternative.
    9) Does anyone know if there are any plans to update the Core as it’s very highly priced for what it is, has limited input options (just 1 really, a choice of analogue or optical), so if there’s a chance it will be updated then I’d hold off. Only the faintest of rumors as far as I can tell. Since they’re moving to more “intelligent” speakers I almost wonder if they’ll phase that sort of product out eventually, but it would be ludicrous considering they’d need something to drive in-walls/in-ceilings, etc. to complete a whole home. But definitely nothing worth waiting for.
