Reply To: Back to old things: Beovox P50…
#4953
pepps
GOLD Member
    • Kent, UK
    Hello,
    The effect of wall mounting to improve the sound is in principal very similar to any non-rear-ported speaker enclosure. On a solid wall they’ll sound stronger than on a stud wall or on brackets.
    Similar thinking to placing a rear-ported speaker on a nice solid stand.
    The writing from B&O on the topic does suggest something magical will happen, but it’s just good sense to use a solid foundation on which to position the speakers.
    Get the tweeters at ear level and you’ll achieve a lovely stereo image. Hang them higher and you’ll get a more bass-heavy and floaty effect, depending on the amount of soft furnishings or reflective surfaces in your listening room.
    Julian
