May 12, 2022 at 7:42 am
#4949
Hi jjcox,
Whilst the NL/ML Converter is an option, you can get great results with a £20 cable, without needing the £650 converter.
This cable will connect from one of the Powerlink outputs of the Beosound 3000 to the 3.5mm line input of your Core:-
Please set the Beosound volume to a high level (50-75%) to give you the full range of volume control from the B&O app.
Alternatively, you can link the Beosound 3000 to the RCA line inputs of the two speakers directly via this cable:-
(IMPORTANT NOTE: ONLY BEOLAB 5, 17, 18, 19, 20, 28, 50 AND 90 CAN ACCEPT INPUTS FROM MULTIPLE DEVICES AT THE SAME TIME, OTHER SPEAKERS CANNOT DO THIS!)
Kind regards, Steve.
This reply was modified 1 month, 2 weeks ago by
Steve at Sounds Heavenly.
