Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4004 short circuit? › Reply To: Beogram 4004 short circuit?
Hello Karl,
I am not a real savy tech person, but until someone with more knowledge steps in I will give you my thoughts on your problem. You should at least see a light on the control panel, left side for 33 rpm if the table is getting power when you push the start button. If the capacitors have not been replaced, they probably are the first thing to go after 40 some years. There is a fuse box in the back left side under the top plates that you could check. If a fuse was blown there was probably a good reason however.
Depending on where you live, there are people who could service the table, if you have no basic soldering and electronic skills that might be the best course of action.
John
