May 7, 2022 at 2:57 am
#4844
That model has many electrolytic caps that by now have started to fail. That is usually the cause of it spinning backwards. You should start by replacing them in the power supply and motor/coil section. Once you’ve confirmed correct and stable voltages then you can see if there are other issues.
