Home Forums Product Discussion & Questions BeoVision Weird format issue with beovision avant 28 mkI type 8111 Reply To: Weird format issue with beovision avant 28 mkI type 8111
#48051
Guy
    • Warwickshire, UK
    HI and welcome to Beoworld!
    There is some sort of phenomenon known as ‘RGB shift’ that has been discussed previously on this Forum – it sounds like what you are experiencing.
    It was discussed a little here:  https://archivedforum2.beoworld.org/forums/p/5006/45087.aspx
    But there may be more threads if you do a more comprehensive search – look in AV forums also.
    EDIT:  Also mentioned here: https://www.avforums.com/threads/is-there-a-way-to-correct-rgb-shift.58589/
    From memory I think it can be corrected in the service menu ( I vaguely remember trying), but will probably cause issues with other format (non-RGB) inputs, if you use them.
