Home Forums Product Discussion & Questions BeoMaster Beomaster 6000 FM frequency counter issue Reply To: Beomaster 6000 FM frequency counter issue
#48001
Glitch
Tuning issues are usually caused by a bad U264B chip (IC8-Board2) or a broken wire on the coax cable between the FM board and the CPU board.
Replacement U264B chips can be hit or miss for working with a BM6000 (depending on the manufacturer). The ones sold at beoparts-shop.com work well. The cheap ones from China sometimes work, but you might need to try a handful of them before you find one that is compatible.
The broken coax wire is usually at the CPU end of the cable where the center wire connects to the connector pin. This can be repaired by soldering in a short piece of wire to reestablish the connection.
Glitch
