Reply To: Limited HDMI bandwidth on Eclipse Sound Center 1st Gen ?
#4786
Dyssegaard
    • Copenhagen
    I set ATV to Dolby Vision/60.
    played a video on the YouTube app that was supposed to be DV 60.
    This is what the stats liked like:
    87B571AA-F9A7-4967-9FE2-E3EF0986CA85
    Does is makes sense?
    Thanks again for checking.
    And yes – it does make sense.
    I don’t think that it was displayed in DV or HDR. If you look at the Codecs line it should have been 9.2.
    I played a DV-video in the webos youtube app and the panel on the TV shifted to HDR-mode.
    Maybe it will work if you force the ATV to HDR/60.
    For youtube videos I will be using the webos app in the tv in the future since it can display HDR/60 videos.
    The problem is with apps like Disney+ and ATV+ since they are not available on Eclipse 1st gen. They are available on the normal LG C7. I have been in contact with B&O about the missing apps. They are aware, but suggest to buy an ATV and use the apps there ..
    Best Regards
    Dyssegaard
    • This reply was modified 1 year, 4 months ago by Dyssegaard. Reason: To be deleted - link to picture failed
