Reply To: Beolink 5000 E-Ink screen repair / mod
#4769
pilatomic
    ERRATUM : Bad wiring diagram in installation manual.
    There was a mistake in the section 6, about the signals connections on the MHS CPU. The RST pin was incorrectly placed.
    I apologize for this mistake !
    If you ran a jumper wire to the wrong pin in an attempt to make the connection according to this diagram, it does not seem to cause any issue, but it is better to remove it.
    The installation manual v1.1 contains the correct diagram.
    • This reply was modified 1 year, 4 months ago by pilatomic. Reason: Changed formulation
