Reply To: Beolab 5000 Type 5303
#4694
Pindsen
    • Denmark
    Hi again.
    Thanx for helping. You where right regarding using the phono plugs, then there are sound using the Tuner and AUX input.
    Regarding the power supply issue the 33V part is OK but the 60V is wrong. I have found that component 471 (SE8002) is shorted between B-C (4 ohm). I am not able to find a SE8002 but according to this old post a 2N2102 should do the job:
    https://archivedforum.beoworld.org/forums/p/40097/335005.aspx#335005
    /Pindsen
