May 3, 2022 at 12:44 pm
#4660
I have the aerial connected to the ‘middle’ socket.
I just had a quick look at the manual and I think that’s the correct one, so your problem must be elsewhere. Do you have another TV that you could connect temporarily to check the rest of the antenna path?
Also, do you have the manual so that you can check that you are using the correct tuning method for the digital (rather than analogue) tuner? They are different menus.
