Reply To: BeoCom Technical Advice Required
#4653
Guy
    • Warwickshire, UK
    Thank you trackbeo for your reply, I’m in the United Kingdom and with a provider called Virgin Media using their Hub 4, tried the suggestions with no prevail, seen a lot of people having the same issue in the UK on forums when switching from the old phone lines to VoIP, managed to resolve it tonight if anyone has the same issue in the future… – Unregister all phones – Unplug BeoLine PTSN – Plug back in – Register Phones Fixed the issue
    Thanks for letting us know that the problem is solved. It’s useful to know that Beocoms connected direct to routers/hubs are still likely to work when UK switches off the analogue (copper wire) phone network in 2025. I hope to still be using my Beocom 6000s 😀
