Reply To: how to select DVI on Beovision 6-22
#4629
matador
    • Paris France
    I have Beocenter 6-26 so it may be work differently.
    AV3 is set to an input selectable with an hard key (V.MEM maybe, can’t say because I use a blind Beo6 now, sorry…). Then the HDTV option below is set to DVI.
    I remember that even when I was using a Beo4 It didn’t never required to use the LIST key.
    I even remember it was an AV Beo4 because I used that key to start the BV as a speaker with the picture muted.
    Hope this helps.
