Home Forums Product Discussion & Questions BeoSystem Beosystem 3 screen out to Hdmi Reply To: Beosystem 3 screen out to Hdmi
#46190
Guy
    • Warwickshire, UK
    Great project but a frustrating problem!
    I had a similar problem with DVI but in my case I was trying to feed an Apple TV (hdmi) into a BC6-26 DVI input – the picture would ‘blink’ every few minutes.
    One thing you could try (although it didn’t work in my setup) is a ‘EDID Emulator’.  I don’t know or understand much about them so you’d have to do your own research, but they are used to solve display incompatibilities in many applications and may be worth a try if you have exhausted other options.
    Perhaps others have better knowledge of the use of BS3 with alternative (non-B&O) panels and can help further.
    Good luck – please let us know how you get on.
