Reply To: how to select DVI on Beovision 6-22
#4619
Guy
    • Warwickshire, UK
    Maybe still worth seeing if your Beo4 has the later software – it needs version 3.4 or later.
    Have you tried adding PC to LIST ?  (Press Power and LIST together, then select ADD etc)
    Otherwise best (only) option is to find a newer Beo4 or any BL1000.
    • This reply was modified 1 year, 7 months ago by Guy.
