Home Forums Product Discussion & Questions BeoGram BeoGram 7000 and BeoSystem 3 Reply To: BeoGram 7000 and BeoSystem 3
#45694
Madskp
GOLD Member
Thanks, I added Phono to the list on the Beo4, but still, the beogram 5500 does not react. Pressing AUX on the overture shows AUX on the display and I can hear sound when starting the BG anually – connection is OK. But from what I read in other posts, the overture should then show PHONO as it recognizes the beogram…..correct? IMHO – very strange, as it is reported to work. Arguably an HW defect…i.e. the cable does not have the datalink pin connected – but it looks original and is not removable from the BG.
Do the DIN connector on the Beogram have 7 pins or are some of them missing? Normally the 2 pins in the button can be unscrewed, and one of these carries the data control signal
