Home Forums Product Discussion & Questions BeoLab Beocenter 9500 / Beolab 3500 connection Reply To: Beocenter 9500 / Beolab 3500 connection
#45680
speedsixdave
    Hi Mads,
    Thanks very much for that, some useful things to try there. I’m away for a few days but will try when I get back.
    There was a cut-off ML plug in the back of the Beolab when I bought it so it may well be set to use the Masterlink at the moment,
    As you suspect the plan is for the BL3500 to go in a different room eventually so Opt 6 sounds right, but at the moment it is in my lounge attached to the BC9500 by a fairly short MCL cable.
