Reply To: Beomaster 6000 Type 2702 service manual
#4357
Vinlyfrontier57
    Thanks for your post, Craig (#4161).
    I checked the 20V and 21V rails that are generated on PCB2.  They measured 10V and 11.5V respectively, so there is a problem here too.
    Can you by any chance remember which components had failed on your unit?  Was it the regulator transistor (2TR8) on the cct diagram?
    Thanks,
    Phil (Vinylfrontier57)
